Salta al contenuto principale
Mercedes W123 Glow Plug Fuse and Fuse Box, Early Style Replacement
Cosa ti serve
  1. Mercedes W123 Glow Plug Fuse and Fuse Box, Early Style Replacement, Glow Plug Fuse and Fuse Box, Early Style: passo 1, immagine 1 di 1
    • The fuse box on early W123 cars, those with the glow plug relay inside the car and under the dash, usually 1980 and earlier, are located on the firewall back behind several of the soft rubber heater hoses. The location makes it difficult to photograph the fuse box when installed.
    • To uninstall the fuse box simply locate it on the firewall and remove the two Phillips head screws that hold it to the firewall. These are the Phillips screws located on the upper right and lower left corners of the fuse box, outside of the fuse box cover.
    • Once the fuse box is removed from the firewall it can be gently pulled forward for easier access to the screws holding the wires and fuse in place inside the box. As shown, once you've pulled the box out from under the coolant hoses you can remove the two remaining Phillips head screws and then remove the fuse box and old fuse.
  2. Mercedes W123 Glow Plug Fuse and Fuse Box, Early Style Replacement: passo 2, immagine 1 di 3 Mercedes W123 Glow Plug Fuse and Fuse Box, Early Style Replacement: passo 2, immagine 2 di 3 Mercedes W123 Glow Plug Fuse and Fuse Box, Early Style Replacement: passo 2, immagine 3 di 3
    • With the fuse box removed it and the fuse can be inspected. This fuse box was removed because excess heat caused the fuse box plastic to melt. This allowed the copper fuse connection on the left to be pulled to the right within the body of the fuse box. Eventually the two copper sections would touch, bypassing the fuse.
    • The old, damage box is shown on the left while the replacement box is shown on the right.
    • See how the fuse is bent in the middle as it's left-side connection was pulled to the right.
    • In this case this was caused by the timer on the glow plug relay no longer functioning after the glow system on the older style glow plug system after it was converted to the fast glow plug system. The glow plugs stayed hot, with 12V going through the fuse, while testing the window regulators on this car.
  3. Mercedes W123 Glow Plug Fuse and Fuse Box, Early Style Replacement: passo 3, immagine 1 di 1
    • Replace the fuse box with the new one, and install a new 80 or 50 amp fuse (check to see which fuse to use, depending on year and model). Screw in the two Phillips head screws that hold the glow plugs wires to the fuse and fuse box, and then reattach the new fuse box to the firewall.
Conclusione
Altre 2 persone hanno completato questa guida.
Nicolas Siemsen
Membro da: 12/06/13
39.040 Reputazione
79 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.535 Guide realizzate
Un commento
I just replaced glow plugs in my Mercedes Benz 300 CD 1979 with new ones( not pencil type). Now as soon as I turn the key glow plug fuse burnt out. What did I do wrong?
Idrejorb - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 80
Tutti i Tempi: 16,073
