Salta al contenuto principale
Mercedes W123 Diesel Fuel Filter, Primary Replacement
Cosa ti serve
  1. Mercedes W123 Diesel Fuel Filter, Primary Replacement, Fuel Filter, Primary: passo 1, immagine 1 di 1
    • Here is your clear fuel primary filter. It is located directly next to the fuel primer pump.
  2. Mercedes W123 Diesel Fuel Filter, Primary Replacement: passo 2, immagine 1 di 1
    • Begin by loosening this hose clamp, at the top of the primary filter, nearest the engine.
    • Pull the primary filter up and out of this hose. A small amount of fuel will leak out, consider putting a towel, plastic bag, or other appropriate catch underneath.
  3. Mercedes W123 Diesel Fuel Filter, Primary Replacement: passo 3, immagine 1 di 1
    • Now loosen the clamp on the bottom of the primary filter, further from the engine.
    • You will now be able to pull the filter out the rest of the way. The fuel in it will drain out, catch it with towel or something similar.
  4. Mercedes W123 Diesel Fuel Filter, Primary Replacement: passo 4, immagine 1 di 1
    • Here is the old primary filter, removed from the car. Note the large chunks of debris in the filter.
  5. Mercedes W123 Diesel Fuel Filter, Primary Replacement: passo 5, immagine 1 di 1
    • You can see here the new primary filter. Note that the filter is usually marked with an arrow noting the direction of fuel flow. It should be installed with this arrow pointing towards the engine.
  6. Mercedes W123 Diesel Fuel Filter, Primary Replacement: passo 6, immagine 1 di 1
    • Install the new filter by retracing the steps so far, just backwards.
    • This is a good time to consider replacing the large secondary filter. If you would like guidance on this, see the secondary fuel filter replacement guide.
    • Then, pump the primer pump on the car until the primary filter fills with fuel. It's normal for there to be a small air bubble in the primary filter but it should be mostly clear.
Conclusione
When finished, run the engine to ensure it's been primed properly.
Altre 13 persone hanno completato questa guida.
Nicolas Siemsen
Membro da: 12/06/13
39.040 Reputazione
79 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.528 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 83
Tutti i Tempi: 16,746
