Salta al contenuto principale
Mercedes W123 Battery Ground Cable Replacement
Cosa ti serve
  1. Mercedes W123 Battery Ground Cable Replacement, Disconnect the battery: passo 1, immagine 1 di 2 Mercedes W123 Battery Ground Cable Replacement, Disconnect the battery: passo 1, immagine 2 di 2
    • Start by disconnecting both battery terminals, beginning with the negative (-) side, which travels just a few inches to a bolt attaching the other end to the car's body.
    • Never remove your positive (+) cable first or you risk injury from electric shock.
  2. Mercedes W123 Battery Ground Cable Replacement, Remove the old ground cable: passo 2, immagine 1 di 1
    • Loosen and remove this 13mm bolt that holds the cable to the metal of the car's chassis.
    • Now remove the old ground cable.
  3. Mercedes W123 Battery Ground Cable Replacement, Install the new cable: passo 3, immagine 1 di 2 Mercedes W123 Battery Ground Cable Replacement, Install the new cable: passo 3, immagine 2 di 2
    • You can see here that the new ground cable is substantially thicker. It is a 2 gage cable. The ends are also crimped better, protecting the inner wire from corrosion.
    • This cable is also a bit longer than the old one, giving some more wiggle room.
  4. Mercedes W123 Battery Ground Cable Replacement: passo 4, immagine 1 di 1
    • Install the new ground cable, using the new captive bolt, and nut, that came with it.
Conclusione
Once you've finished, consider covering the terminal where the cable attaches to the battery in a silicone dielectric grease to prevent corrosion.
Altre 12 persone hanno completato questa guida.
Nicolas Siemsen
Membro da: 12/06/13
39.010 Reputazione
79 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.522 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 41
Tutti i Tempi: 8,824
