Salta al contenuto principale
Merangue Steel 3-Hole Punch Head Replacement
Cosa ti serve
  1. Merangue Steel 3-Hole Punch Head Replacement, Punch Head: passo 1, immagine 1 di 3 Merangue Steel 3-Hole Punch Head Replacement, Punch Head: passo 1, immagine 2 di 3 Merangue Steel 3-Hole Punch Head Replacement, Punch Head: passo 1, immagine 3 di 3
    • Tilt the hole puncher on its back.
    • Use a flathead screwdriver to remove the three screws.
  2. Merangue Steel 3-Hole Punch Head Replacement: passo 2, immagine 1 di 3 Merangue Steel 3-Hole Punch Head Replacement: passo 2, immagine 2 di 3 Merangue Steel 3-Hole Punch Head Replacement: passo 2, immagine 3 di 3
    • Use your finger to slide the punch head out towards the opening (right in this case).
    • Remove the punch head from the opening and set it aside.
    • Repeat this step with the other punch heads.
  3. Merangue Steel 3-Hole Punch Head Replacement: passo 3, immagine 1 di 3 Merangue Steel 3-Hole Punch Head Replacement: passo 3, immagine 2 di 3 Merangue Steel 3-Hole Punch Head Replacement: passo 3, immagine 3 di 3
    • Take your replacement hole punch and push it into the opening.
    • Slide the hole punch to your desired alignment in my case, left).
    • Make sure the hole punch is properly aligned (the hole at the back should point directly at the ceiling).
  4. Merangue Steel 3-Hole Punch Head Replacement: passo 4, immagine 1 di 3 Merangue Steel 3-Hole Punch Head Replacement: passo 4, immagine 2 di 3 Merangue Steel 3-Hole Punch Head Replacement: passo 4, immagine 3 di 3
    • Use your fingers to screw one of the screws into the hole on the back of the punch head.
    • The screw can be a bit difficult to align so be patient and don't rush.
    • Take your flat head screwdriver and tighten the screw.
    • Repeat these steps for the other punch heads.
Linea Traguardo
Noah Dela Calzada
Membro da: 01/16/24
109 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 52
