Salta al contenuto principale
Memorex CD Alarm Clock Radio PCB Board Replacement
Cosa ti serve
  1. Memorex CD Alarm Clock Radio PCB Board Replacement, Memorex CD Alarm Clock Radio: passo 1, immagine 1 di 3 Memorex CD Alarm Clock Radio PCB Board Replacement, Memorex CD Alarm Clock Radio: passo 1, immagine 2 di 3 Memorex CD Alarm Clock Radio PCB Board Replacement, Memorex CD Alarm Clock Radio: passo 1, immagine 3 di 3
    • Turn the clock radio over so the bottom is facing up.
    • Pull the tab upward and remove the cover from the battery compartment.
    • Remove the batteries.
  2. Memorex CD Alarm Clock Radio PCB Board Replacement: passo 2, immagine 1 di 3 Memorex CD Alarm Clock Radio PCB Board Replacement: passo 2, immagine 2 di 3 Memorex CD Alarm Clock Radio PCB Board Replacement: passo 2, immagine 3 di 3
    • Remove the five screws on the bottom of the device with a screwdriver.
    • Grasp the top and bottom and gently pull apart.
  3. Memorex CD Alarm Clock Radio PCB Board Replacement, PCB Board: passo 3, immagine 1 di 1
    • Remove the (5) 7mm screws with a Phillips #1 screwdriver and a pair of tweezers.
    • Using a magnetic tip screwdriver will prevent screw loss.
  4. Memorex CD Alarm Clock Radio PCB Board Replacement: passo 4, immagine 1 di 3 Memorex CD Alarm Clock Radio PCB Board Replacement: passo 4, immagine 2 di 3 Memorex CD Alarm Clock Radio PCB Board Replacement: passo 4, immagine 3 di 3
    • Locate the wiring harness.
    • Disconnect the wiring harness using the tweezers.
  5. Memorex CD Alarm Clock Radio PCB Board Replacement: passo 5, immagine 1 di 1
    • Remove the PCB board from the device.
    • Replace the broken motherboard with a new PCB board.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 330
