Remove the water tank and drainage tray.
Remove the side cover and remove the brewing unit.
Remove all coffee beans.
Press carefully into the slits on the sides using a minus screwdriver or a flat metal spatula, to release the clasps on the upper surface. These may be well tight and you have to use some force.
You should have created a separation between the upper surface and side panels. Now lever the upper covering away using a plastic tool. This may be quite stuck and you may apply some force.
Repeat the steps in reverse order to reassemble your device.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
2 Commenti
Sehr schöne Anleitung! Stehe gerade vor der selben Maschine und prüfe gerade warum kein Wasser herauskommt.
Schläuche wurden geprüft, Flowmeter geprüft, ist alles freigängig. Pumpe drückt Wasser bis zum Erhitzer. Ich denke dieser ist verkalkt.
Schöne Anleitung, enthält alles was man braucht!
Zum Prüfen einfach reinblasen. Muss ziemlich leicht gehen.
VauWeh -
