The backside is fixed with seven Torx T10 screws. Unscrew them
Get the Backside of. It should be a bit stuck.
Pull the powder compartment up.
Pull one of the sides of the Powder compartment out of the hinge and loosen the lid.
Remove the powder compartment
In the powder compartment, you should see a rubber cover. Loosen the rubber cover with the appropriate tools.
There should also be a Torx T10 screw. Unscrew it
The upper cover with the brewing unit is held up from three clamps. These can be reached through a slit.
Press these clams with a flat scredriver in and pull the upper cover up, until the clamps loosen.
On the side that has a a watertank you can find 2 other clamps
Press these clamps with a flat scredriver in and pull the cover up until they loosen
Lift the upper cover and the backside up, hook it on the front edge and remove them
Push the right and the left side panel back, then pull the lower edge out and pull the side panel out.
On the side panel with the watertank, there should be a supply hose attached to a cable that connects the water-level sensore. loosen them
Hint: the side panel doesn't have to be removed completely for each repair.
Work through the steps in reverse order, to rebuild your machine.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
