Salta al contenuto principale
Maze Speed SSB-508 Power and Volume Button Replacement
Cosa ti serve
  1. Maze Speed SSB-508 Power and Volume Button Replacement, Power and Volume Buttons: passo 1, immagine 1 di 3 Maze Speed SSB-508 Power and Volume Button Replacement, Power and Volume Buttons: passo 1, immagine 2 di 3 Maze Speed SSB-508 Power and Volume Button Replacement, Power and Volume Buttons: passo 1, immagine 3 di 3
    • Remove the back cover by gently prying open the bottom left corner of the case with the plastic opening tool.
    Chiedi a FixBot
  2. Maze Speed SSB-508 Power and Volume Button Replacement: passo 2, immagine 1 di 2 Maze Speed SSB-508 Power and Volume Button Replacement: passo 2, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    • There are three areas holding the power and volume buttons in place. Gently pull the bottom of the power button with a pair of fine-tip tweezers to release the lower half.
    Chiedi a FixBot
  3. Maze Speed SSB-508 Power and Volume Button Replacement: passo 3, immagine 1 di 3 Maze Speed SSB-508 Power and Volume Button Replacement: passo 3, immagine 2 di 3 Maze Speed SSB-508 Power and Volume Button Replacement: passo 3, immagine 3 di 3
    • Carefully remove the top section of the button with the fine-tip tweezers . This should free the button completely.
    Chiedi a FixBot
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 42
Tutti i Tempi: 569
