Introduzione
This guide will provide you the process of replacing the battery port in a Maze Speed phone. You will need a plastic opening tool, tweezers, a Phillips #00 Screwdriver, pliers and soldering equipment. You will also need to know how to solder, in order to not damage other components. Sometimes a phone battery connector may get corroded which shortens the battery life. If this is the case, you will need to change the battery port.
Cosa ti serve
Remove the back cover by inserting the plastic opening tool at the bottom left corner of the device.
Strumento utilizzato in questo passaggio:Tweezers$4.99
Use tweezers to remove cable from the ZIF connectors located at the bottom left of the motherboard.
Use the tweezers to remove the second cable from ZIF connector located to the right of the speaker that you unplugged in step five.
Flip the motherboard upside down and you will see the battery port connected to the motherboard with 5 different soldered places.
Use the pliers to hold the motherboard and desolder the 5 places which are connected to the motherboard.
