Salta al contenuto principale
Maytag Bravos Drive Belt Replacement
Cosa ti serve
  1. Maytag Bravos Drive Belt Replacement, Drive Belt: passo 1, immagine 1 di 1
    • Disconnect the power supply from your Maytag Bravos washer. Following this, pull the device approximately 2 feet away from the wall.
    Chiedi a FixBot
    Aggiungi Commento
  2. Maytag Bravos Drive Belt Replacement: passo 2, immagine 1 di 2 Maytag Bravos Drive Belt Replacement: passo 2, immagine 2 di 2
    • This step may be easier with two people.
    • Gently rest the washing machine against a wall or hard surface to keep it slightly elevated. This is important as you will need access to the underside of the machine for the following step.
    Chiedi a FixBot
    Aggiungi Commento
  3. Maytag Bravos Drive Belt Replacement: passo 3, immagine 1 di 1
    • Have your 1/4-inch drive ratchet ready for the following step.
    Chiedi a FixBot
    Aggiungi Commento
  4. Maytag Bravos Drive Belt Replacement: passo 4, immagine 1 di 2 Maytag Bravos Drive Belt Replacement: passo 4, immagine 2 di 2
    • Have someone carefully watch over the washing machine and make sure it is firmly rested against the wall to prevent injury.
    • Under the washing machine you will see a plastic cover over the drive belt. To remove this use your 1/4" drive ratchet.
    Chiedi a FixBot
    Aggiungi Commento
  5. Maytag Bravos Drive Belt Replacement: passo 5, immagine 1 di 1
    • Following the removal of the cover, place the bolts inside the cover and place to the side somewhere safe.
    Chiedi a FixBot
    Aggiungi Commento
  6. Maytag Bravos Drive Belt Replacement: passo 6, immagine 1 di 1
    • Following removal of the cover you will see the drive belt roped around two cogs.
    • The belt is fairly elastic and easy to remove. Remove the drive belt gently and replace with the new belt.
    Chiedi a FixBot
    Aggiungi Commento
  7. Maytag Bravos Drive Belt Replacement: passo 7, immagine 1 di 1
    • Reattach the drive belt cover using your 1/4" drive ratchet.
    Chiedi a FixBot
    Aggiungi Commento
  8. Maytag Bravos Drive Belt Replacement: passo 8, immagine 1 di 2 Maytag Bravos Drive Belt Replacement: passo 8, immagine 2 di 2
    • Gently rest the washing machine back against the wall and reconnect all power supply.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
To replace your drive belt in your Maytag Bravos washer follow this simple 8 step guide.
Altre 4 persone hanno completato questa guida.
2Commenti sulla guida
What’s the trick of getting the new belt on the wheels?
palmer910 - Rispondi Condividi
Where can I find a drive belt for a Maytag Bravos MVWB750WQ0??? I have looked and looked online, and cannot find a source!
J Lipson - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 34
Ultimi 30 giorni: 185
Tutti i Tempi: 22,339
