Salta al contenuto principale
Maylong MN-1000P Battery Replacement
Cosa ti serve
  1. Maylong MN-1000P Battery Replacement, Bottom Cover: passo 1, immagine 1 di 1
    • Place the netbook top down, with the opening of the netbook facing you.
  2. Maylong MN-1000P Battery Replacement: passo 2, immagine 1 di 1
    • Remove the six 6mm Phillips #00 screws from the netbook.
  3. Maylong MN-1000P Battery Replacement: passo 3, immagine 1 di 3 Maylong MN-1000P Battery Replacement: passo 3, immagine 2 di 3 Maylong MN-1000P Battery Replacement: passo 3, immagine 3 di 3
    • Remove the sticker in the middle of the netbook.
    • Remove the middle 6mm Phillips #00 screw.
  4. Maylong MN-1000P Battery Replacement: passo 4, immagine 1 di 1
    • Using two plastic opening tools, pry off the bottom of the netbook by going around the edges.
  5. Maylong MN-1000P Battery Replacement: passo 5, immagine 1 di 1
    • Remove the bottom of the netbook by lifting the corners.
  6. Maylong MN-1000P Battery Replacement, Battery: passo 6, immagine 1 di 2 Maylong MN-1000P Battery Replacement, Battery: passo 6, immagine 2 di 2
    • Pinch the red and black wires connected to the section closest to the small white connector, and pull to remove them from the motherboard.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 192
