Salta al contenuto principale
Maylong M-270 Motherboard Replacement
Cosa ti serve
  1. Maylong M-270 Motherboard Replacement, Motherboard: passo 1, immagine 1 di 2 Maylong M-270 Motherboard Replacement, Motherboard: passo 1, immagine 2 di 2
    • Use the plastic opening tool to separate the back cover plate from the front.
    • Insert the plastic opening tool in between the back plate cover and the top cover, then slide along edges to pry open.
  2. Maylong M-270 Motherboard Replacement: passo 2, immagine 1 di 2 Maylong M-270 Motherboard Replacement: passo 2, immagine 2 di 2
    • Locate the two ribbons attached to the device's motherboard.
    • Flip the small black plastic catches down by using the small end of the spudger.
    • Remove the ribbons by gently pulling them away from the motherboard.
  3. Maylong M-270 Motherboard Replacement: passo 3, immagine 1 di 2 Maylong M-270 Motherboard Replacement: passo 3, immagine 2 di 2
    • Remove the two screws from the motherboard.
    • Remove the four screws and metal holds from the edge of the device.
  4. Maylong M-270 Motherboard Replacement: passo 4, immagine 1 di 1
    • Remove the motherboard by gently pulling it away from the bottom of the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 534
