Salta al contenuto principale
MaxWest TAB-7360DC Battery Replacement
Cosa ti serve
  1. MaxWest TAB-7360DC Battery Replacement, Back Hard Case: passo 1, immagine 1 di 3 MaxWest TAB-7360DC Battery Replacement, Back Hard Case: passo 1, immagine 2 di 3 MaxWest TAB-7360DC Battery Replacement, Back Hard Case: passo 1, immagine 3 di 3
    • Insert plastic opening tool at the corner of the screen, in between the back case and the front.
    • Volume buttons will fall out during removal.
    • When opening up the case, have the I/O ports facing you and turn the back case towards the right. There is a short wire connecting the speaker to the logic board.
  2. MaxWest TAB-7360DC Battery Replacement: passo 2, immagine 1 di 2 MaxWest TAB-7360DC Battery Replacement: passo 2, immagine 2 di 2
    • Carefully pry the tape from the battery, the bottom left chip, and the ribbon cable towards the bottom-right of the board. The bottom left has a little silver square component that must also be unclipped and untaped.
    • The battery is glued to the back of the screen; therefore pull the battery off of the back with caution. There will be resistance but that's okay.
  3. MaxWest TAB-7360DC Battery Replacement: passo 3, immagine 1 di 1
    • Gently unclip the data cable retainers and remove the wires from the junctions.
    • Peel the tape off the wire near the bottom of the case.
  4. MaxWest TAB-7360DC Battery Replacement: passo 4, immagine 1 di 1
    • Remove the two 4mm screws (circled in orange) with a 00 Phillips head driver.
    • Unclip the black plastic retainer near the data port. The PCB should now be able to be gently pulled off.
  5. MaxWest TAB-7360DC Battery Replacement: passo 5, immagine 1 di 1
    • Make contact with the battery terminals with the hot tip of the soldering iron for a few seconds while slowly pulling the wire away.
    • DO NOT TOUCH BOTH THE BLACK AND RED LEADS AT THE SAME TIME WITH THE SOLDERING IRON
Conclusione
Gillian Bundles
Membro da: 03/21/18
221 Reputazione
1 Guida realizzata
IUPUI, Team S4-G3, Baechle Spring 2018 Membro di IUPUI, Team S4-G3, Baechle Spring 2018
IUPUI-BAECHLE-S18S4G3
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 50
Tutti i Tempi: 1,574
