Salta al contenuto principale
Mavic 2 Main Board Replacement
Cosa ti serve
  1. Mavic 2 Main Board  Replacement, Remove screws: passo 1, immagine 1 di 1
    • Begin to remove screws from belly of drone.
  2. Mavic 2 Main Board  Replacement, Continue to remove screws: passo 2, immagine 1 di 3 Mavic 2 Main Board  Replacement, Continue to remove screws: passo 2, immagine 2 di 3 Mavic 2 Main Board  Replacement, Continue to remove screws: passo 2, immagine 3 di 3
    • remove the rest of the screws
  3. Mavic 2 Main Board  Replacement: passo 3, immagine 1 di 2 Mavic 2 Main Board  Replacement: passo 3, immagine 2 di 2
    • After all 8 Screws are removed. Remove the back panel. Keep in mind there is a ribbon connecting the panel and the main board. You must detach the ribbon from either side.
  4. Mavic 2 Main Board  Replacement: passo 4, immagine 1 di 1
    • Unscrew the screws holding the board in place, as well as all the ribbons and antennas connecting the board to the frame.
  5. Mavic 2 Main Board  Replacement: passo 5, immagine 1 di 1
    • Then remove the old board. Replace the new board you have and repeat the process in reverse.
Conclusione
Altre 2 persone hanno completato questa guida.
Un commento
Hello sir,
I have a question and I hope to find the answer
The plane (Mavic 2) collided with a pilot turned into a pole, and after that, I find a stutter in the camera from time to time, so I hope to find a way to solve this problem since the camera works, the camera shake.
Amr Ahmed - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 28
Tutti i Tempi: 1,459
