Salta al contenuto principale
Mavic 2 Arm Replacement
Cosa ti serve
  1. Mavic 2 Arm Replacement, Front Arm (Left or Right): passo 1, immagine 1 di 1
    • Remove the two M2x5 screws from the plastic cover by the camera using and H1.5 Allen bit.
  2. Mavic 2 Arm Replacement: passo 2, immagine 1 di 1
    • Gently remove the cover by the front camera by wiggling out the clips holding it in on both sides.
  3. Mavic 2 Arm Replacement: passo 3, immagine 1 di 3 Mavic 2 Arm Replacement: passo 3, immagine 2 di 3 Mavic 2 Arm Replacement: passo 3, immagine 3 di 3
    • Remove the six M2x5 screws from the bottom plastic cover using a H1.5 Allen bit.
    • Remove the plastic cover once all screws are extracted.
  4. Mavic 2 Arm Replacement: passo 4, immagine 1 di 2 Mavic 2 Arm Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Using tweezers or a plastic pick, remove either the white or black wire plugging into the board.
    • Be gentle removing the wire from the plug, you can damage the plug on the board.
    • The wire being pulled depends on which arm is being replaced. The wire that is closest to the arm being replaced is the one to unplug.
  5. Mavic 2 Arm Replacement: passo 5, immagine 1 di 3 Mavic 2 Arm Replacement: passo 5, immagine 2 di 3 Mavic 2 Arm Replacement: passo 5, immagine 3 di 3
    • Unscrew the two M2x5 screws holding on the front nose.
    • Using a plastic pry tool, gently pry along the seem around the front nose to remove it.
  6. Mavic 2 Arm Replacement: passo 6, immagine 1 di 2 Mavic 2 Arm Replacement: passo 6, immagine 2 di 2
    • Remove all ten M2x5 mm screws holding the top plastic cover of the drone. Two at the back, four in the battery bay, and two at each front arm joint.
    • At each arm joint, only one screw is visible. The second screw is under the plastic piece being held on by the first screw.
  7. Mavic 2 Arm Replacement: passo 7, immagine 1 di 3 Mavic 2 Arm Replacement: passo 7, immagine 2 di 3 Mavic 2 Arm Replacement: passo 7, immagine 3 di 3
    • Using a plastic pry tool, pry along the seem around the top cover to separate it from the chassis. Be patient as it does take a bit of time and effort to get it off.
  8. Mavic 2 Arm Replacement: passo 8, immagine 1 di 2 Mavic 2 Arm Replacement: passo 8, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove the screw that secures the arm spring.
    • Then remove the spring, use either tweezers or a flat-head screwdriver to lift it up out of the arm.
  9. Mavic 2 Arm Replacement: passo 9, immagine 1 di 2 Mavic 2 Arm Replacement: passo 9, immagine 2 di 2
    • On the topside of the drone,desolder the wires from the main board that correspond to the arm trying to be replaced, there should be six in total.
    • Remove the arm once all wires are desoldered.
    • Make note of where each wire goes on the board as the colors may not be the same across all models.
Conclusione
Nick Imel
Membro da: 11/09/23
178 Reputazione
1 Guida realizzata
IUPUI, Team 2-3, Harley Fall 2023 Membro di IUPUI, Team 2-3, Harley Fall 2023
IUPUI-HARLEY-F23S2G3
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 63
Tutti i Tempi: 902
