Salta al contenuto principale
Matsunichi MarquisPad MP977 Plastic Front Panel Replacement
Cosa ti serve
  1. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement, Plastic Front Panel: passo 1, immagine 1 di 1
    • Remove the two screws using a PH #00 Phillips head screw driver.
  2. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: passo 2, immagine 1 di 3 Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: passo 2, immagine 2 di 3 Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: passo 2, immagine 3 di 3
    • Place the device face down on a flat surface.
    • Insert one of the wide tipped, plastic opening tools into the top of the left speaker slot.
    • Be sure not to puncture the covering of the speaker.
    • Pry the back plate open and slide the tool in a clockwise direction, moving it along the opening between the device and its back plate until you reach the power button.
  3. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: passo 3, immagine 1 di 2 Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: passo 3, immagine 2 di 2
    • Insert opening tool into the right speaker slot.
    • Pry open the back plate, and slide the tool counter clockwise along the device until you reach the charging port.
  4. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: passo 4, immagine 1 di 1
    • Remove the back plate and place it to the side.
  5. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: passo 5, immagine 1 di 1
    • Remove the screws holding the metal frame plate in place.
    • Remove the metal frame plate from the plastic housing.
  6. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: passo 6, immagine 1 di 2 Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: passo 6, immagine 2 di 2
    • Place the metal frame plate and components into the new plastic front panel.
Conclusione
Un commento
where can you order the front plastic panel from? and how much?
daf01ca - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 380
