Salta al contenuto principale
Matsunichi MarquisPad MP977 Battery Replacement
Cosa ti serve
  1. Matsunichi MarquisPad MP977 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the two screws using a Phillips #00 screwdriver.
  2. Matsunichi MarquisPad MP977 Battery Replacement: passo 2, immagine 1 di 3 Matsunichi MarquisPad MP977 Battery Replacement: passo 2, immagine 2 di 3 Matsunichi MarquisPad MP977 Battery Replacement: passo 2, immagine 3 di 3
    • Place the device face down on a flat surface.
    • Insert one of the wide-tipped, plastic opening tools into the top of the left speaker slot.
    • Be sure to avoid puncturing the covering of the speaker.
    • Pry the back plate open and slide the tool in a clockwise direction, moving it along the opening between the device and its back plate until you reach the power button.
  3. Matsunichi MarquisPad MP977 Battery Replacement: passo 3, immagine 1 di 2 Matsunichi MarquisPad MP977 Battery Replacement: passo 3, immagine 2 di 2
    • Insert the opening tool into the right speaker slot.
    • Pry open the back plate, and slide the tool counterclockwise along the device until you reach the charging port.
  4. Matsunichi MarquisPad MP977 Battery Replacement: passo 4, immagine 1 di 1
    • Remove the back plate and place it to the side.
  5. Matsunichi MarquisPad MP977 Battery Replacement: passo 5, immagine 1 di 2 Matsunichi MarquisPad MP977 Battery Replacement: passo 5, immagine 2 di 2
    • Detach the battery from the motherboard.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,554
