Salta al contenuto principale
Marvel iHome MR-M66 Back Cover Replacement
Cosa ti serve
  1. Marvel iHome MR-M66 Back Cover Replacement, Back Cover: passo 1, immagine 1 di 2 Marvel iHome MR-M66 Back Cover Replacement, Back Cover: passo 1, immagine 2 di 2
    • Remove two of the three screws shown on the bottom of the device.
    • Begin removing the last screw, but leave it partially in the socket to remove the bottom cover easier.
  2. Marvel iHome MR-M66 Back Cover Replacement: passo 2, immagine 1 di 3 Marvel iHome MR-M66 Back Cover Replacement: passo 2, immagine 2 di 3 Marvel iHome MR-M66 Back Cover Replacement: passo 2, immagine 3 di 3
    • Remove the bottom cover by either pulling on the screw or using a plastic opening tool to pry the cover off.
    • After removing the bottom cover, remove the two screws.
  3. Marvel iHome MR-M66 Back Cover Replacement: passo 3, immagine 1 di 3 Marvel iHome MR-M66 Back Cover Replacement: passo 3, immagine 2 di 3 Marvel iHome MR-M66 Back Cover Replacement: passo 3, immagine 3 di 3
    • Use a spudger to release the small retaining clip that holds the feet to the bottom of the device.
    • Be careful here, as too much force can break the clip.
    • Remove the two screws from the back of the device.
  4. Marvel iHome MR-M66 Back Cover Replacement: passo 4, immagine 1 di 3 Marvel iHome MR-M66 Back Cover Replacement: passo 4, immagine 2 di 3 Marvel iHome MR-M66 Back Cover Replacement: passo 4, immagine 3 di 3
    • Using a plastic opening tool and your hand, separate the front and back covers from each other.
    • Starting from the bottom, use the plastic opening tool to create the initial separation and continue along the seam to the top of the device.
    • This step requires the most time and patience, so be careful.
    • The power switch will most likely come loose during this step and you will hear something rattling inside the device.
  5. Marvel iHome MR-M66 Back Cover Replacement: passo 5, immagine 1 di 3 Marvel iHome MR-M66 Back Cover Replacement: passo 5, immagine 2 di 3 Marvel iHome MR-M66 Back Cover Replacement: passo 5, immagine 3 di 3
    • Remove the two arms from either side of the device once a significant separation has been created.
    • They are not fixed to the body itself so you should be able to wiggle them free.
    • Continue pulling the back cover off the device.
    • Remove the red cover for the on/off switch from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 122
