Salta al contenuto principale
Martian Victory Lithium Battery Replacement
Cosa ti serve
  1. Martian Victory Lithium Battery Replacement, Back Plate: passo 1, immagine 1 di 2 Martian Victory Lithium Battery Replacement, Back Plate: passo 1, immagine 2 di 2
    • Unscrew the four 3.4 mm flat head screws
    where to buy this battery?
    Roy Caño - Replica
  2. Martian Victory Lithium Battery Replacement: passo 2, immagine 1 di 1
    • Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
  3. Martian Victory Lithium Battery Replacement, Lithium Battery: passo 3, immagine 1 di 1
    • If not replacing lithium battery, skip down two steps.
    • Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
  4. Martian Victory Lithium Battery Replacement: passo 4, immagine 1 di 1
    • Desolder the battery connections from the motherboard. Learn how to solder components here!
Conclusione
David Miller
Membro da: 10/24/16
246 Reputazione
2 Guide realizzate
IUPUI, Team 3-3, Baechle Fall 2016 Membro di IUPUI, Team 3-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G3
4 Membri
8 Guide realizzate
Un commento
I’m wondering… where did you buy the replacement battery?
Randy Trask - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 831
