Salta al contenuto principale
Marshall Woburn Subwoofer Replacement
Cosa ti serve
  1. Marshall Woburn Subwoofer Replacement, Back Panel: passo 1, immagine 1 di 2 Marshall Woburn Subwoofer Replacement, Back Panel: passo 1, immagine 2 di 2
    • Before starting, unplug the speaker from any power source. After unplugging the device, wait around 10 minutes before starting to let the capacitor fully discharge.
    • On a flat surface, orient the device so that the front grille is facing downward.
    • Using a Phillips #1 screwdriver, remove the ten outer 28.6 mm screws marked in red.
    • Remove the eight inner 28.6 mm screws with the Phillips #1 screwdriver.
  2. Marshall Woburn Subwoofer Replacement: passo 2, immagine 1 di 2 Marshall Woburn Subwoofer Replacement: passo 2, immagine 2 di 2
    • Lift the back input board slightly above the back panel.
    • Rotate the input board so that you can slide it into the hole in the back panel that it came from.
    • Fully slide the input board through the back panel and set it down gently inside the speaker.
  3. Marshall Woburn Subwoofer Replacement: passo 3, immagine 1 di 1
    • Grab the panel by the large hole and lift one side until you can fit your hand under.
    • Use your hand to fully remove the back panel from the rest of the frame.
  4. Marshall Woburn Subwoofer Replacement, I/O Board: passo 4, immagine 1 di 1
    • Disconnect the 5 wires circled in red from the back input board.
    • There may be a little resistance when pulling on the wires, but it should not require excessive force.
  5. Marshall Woburn Subwoofer Replacement: passo 5, immagine 1 di 2 Marshall Woburn Subwoofer Replacement: passo 5, immagine 2 di 2
    • Remove the two 12.7 mm screws marked in red from the front of the back input panel with a Phillips #1 screwdriver.
    • Remove the power input from the back side of the panel.
  6. Marshall Woburn Subwoofer Replacement: passo 6, immagine 1 di 1
    • Completely remove the I/O board and the attached plate.
  7. Marshall Woburn Subwoofer Replacement, Subwoofer: passo 7, immagine 1 di 1
    • Using a Phillips #1 screwdriver, remove the eight 15.8 mm screws attaching the subwoofers to the frame.
  8. Marshall Woburn Subwoofer Replacement: passo 8, immagine 1 di 1
    • Lift each subwoofer up and out of the case and remove them together. This may require some foce.
Conclusione
Kenneth
Membro da: 10/29/23
169 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 35
Tutti i Tempi: 281
