Salta al contenuto principale
Marshall Woburn Back Panel Replacement
Cosa ti serve
  1. Marshall Woburn Back Panel Replacement, Back Panel: passo 1, immagine 1 di 2 Marshall Woburn Back Panel Replacement, Back Panel: passo 1, immagine 2 di 2
    • Before starting, unplug the speaker from any power source. After unplugging the device, wait around 10 minutes before starting to let the capacitor fully discharge.
    • On a flat surface, orient the device so that the front grille is facing downward.
    • Using a Phillips #1 screwdriver, remove the ten outer 28.6 mm screws marked in red.
    • Remove the eight inner 28.6 mm screws with the Phillips #1 screwdriver.
  2. Marshall Woburn Back Panel Replacement: passo 2, immagine 1 di 2 Marshall Woburn Back Panel Replacement: passo 2, immagine 2 di 2
    • Lift the back input board slightly above the back panel.
    • Rotate the input board so that you can slide it into the hole in the back panel that it came from.
    • Fully slide the input board through the back panel and set it down gently inside the speaker.
  3. Marshall Woburn Back Panel Replacement: passo 3, immagine 1 di 1
    • Grab the panel by the large hole and lift one side until you can fit your hand under.
    • Use your hand to fully remove the back panel from the rest of the frame.
Conclusione
NateP
Membro da: 11/01/23
281 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 28
Tutti i Tempi: 156
