Salta al contenuto principale
Marshall Kilburn Tweeters Replacement
Cosa ti serve
  1. Marshall Kilburn Tweeters Replacement, Battery: passo 1, immagine 1 di 2 Marshall Kilburn Tweeters Replacement, Battery: passo 1, immagine 2 di 2
    • Place the unit face down as shown in the picture, exposing the battery cover.
    • Remove the two 4.0mm long screws holding the cover on using a T10 driver.
  2. Marshall Kilburn Tweeters Replacement: passo 2, immagine 1 di 1
    • Remove the battery cover using a fingernail or nylon spudger.
  3. Marshall Kilburn Tweeters Replacement: passo 3, immagine 1 di 1
    • Remove the battery and unplug the power lead.
  4. Marshall Kilburn Tweeters Replacement, Power Switch: passo 4, immagine 1 di 3 Marshall Kilburn Tweeters Replacement, Power Switch: passo 4, immagine 2 di 3 Marshall Kilburn Tweeters Replacement, Power Switch: passo 4, immagine 3 di 3
    • Place speaker as shown in image and remove the four corner 45.5mm back cover screws with a Phillips #2 driver.
    • Using a Phillips #2 driver, remove the six remaining 21.5mm outer back cover screws.
  5. Marshall Kilburn Tweeters Replacement: passo 5, immagine 1 di 2 Marshall Kilburn Tweeters Replacement: passo 5, immagine 2 di 2
    • Remove the back cover by using the vent hole as a grip.
    • Gently pull out the back cover and let it hang on the side of the speaker that has the knobs and power switch.
    • Unplug the main power lead from the control board; this allows the back to be opened more, allowing easy access to the power switch.
  6. Marshall Kilburn Tweeters Replacement: passo 6, immagine 1 di 3 Marshall Kilburn Tweeters Replacement: passo 6, immagine 2 di 3 Marshall Kilburn Tweeters Replacement: passo 6, immagine 3 di 3
    • Pull the back cover attached to the motherboard to the side as shown in first image.
    • Remove the white insulator from the stereo speaker and place it to the side.
  7. Marshall Kilburn Tweeters Replacement: passo 7, immagine 1 di 2 Marshall Kilburn Tweeters Replacement: passo 7, immagine 2 di 2
    • Place the speaker up right, and unscrew the golden bolt around the power switch with your hands, or a wrench.
    • Gently pull out the power switch as shown in the image.
  8. Marshall Kilburn Tweeters Replacement: passo 8, immagine 1 di 3 Marshall Kilburn Tweeters Replacement: passo 8, immagine 2 di 3 Marshall Kilburn Tweeters Replacement: passo 8, immagine 3 di 3
    • Use a slim spudger to wedge out the four red wires attached to the power switch.
  9. Marshall Kilburn Tweeters Replacement, Main Speaker: passo 9, immagine 1 di 3 Marshall Kilburn Tweeters Replacement, Main Speaker: passo 9, immagine 2 di 3 Marshall Kilburn Tweeters Replacement, Main Speaker: passo 9, immagine 3 di 3
    • Unscrew the eight 22.5mm screws of the speaker cover and the device using a Phillips #2 screwdriver.
    • Gently push the speaker cover out of the stereo speaker.
    • Make sure to slowly push out the speaker cover, and not too far because it is still connected to the stereo speaker.
  10. Marshall Kilburn Tweeters Replacement: passo 10, immagine 1 di 3 Marshall Kilburn Tweeters Replacement: passo 10, immagine 2 di 3 Marshall Kilburn Tweeters Replacement: passo 10, immagine 3 di 3
    • Disconnect the blue wires connected to the tweeter.
    • Disconnect the yellow wires connected to the main speaker.
    • Disconnect the red wires connected to the second tweeter.
  11. Marshall Kilburn Tweeters Replacement: passo 11, immagine 1 di 2 Marshall Kilburn Tweeters Replacement: passo 11, immagine 2 di 2
    • Unscrew the four 13.5mm screws connecting the main speaker to the speaker cover, with a Phillips #2 screwdriver.
  12. Marshall Kilburn Tweeters Replacement, Tweeters: passo 12, immagine 1 di 1
    • Remove the four 13.5mm screws that are placed on the tweeters with a Phillips #2 screwdriver.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 25
Tutti i Tempi: 2,794
