Salta al contenuto principale
Marshall Kilburn Power Switch Replacement
Cosa ti serve
  1. Marshall Kilburn Power Switch Replacement, Battery: passo 1, immagine 1 di 2 Marshall Kilburn Power Switch Replacement, Battery: passo 1, immagine 2 di 2
    • Place the unit face down as shown in the picture, exposing the battery cover.
    • Remove the two 4.0mm long screws holding the cover on using a T10 driver.
  2. Marshall Kilburn Power Switch Replacement: passo 2, immagine 1 di 1
    • Remove the battery cover using a fingernail or nylon spudger.
  3. Marshall Kilburn Power Switch Replacement: passo 3, immagine 1 di 1
    • Remove the battery and unplug the power lead.
  4. Marshall Kilburn Power Switch Replacement, Power Switch: passo 4, immagine 1 di 3 Marshall Kilburn Power Switch Replacement, Power Switch: passo 4, immagine 2 di 3 Marshall Kilburn Power Switch Replacement, Power Switch: passo 4, immagine 3 di 3
    • Place speaker as shown in image and remove the four corner 45.5mm back cover screws with a Phillips #2 driver.
    • Using a Phillips #2 driver, remove the six remaining 21.5mm outer back cover screws.
  5. Marshall Kilburn Power Switch Replacement: passo 5, immagine 1 di 2 Marshall Kilburn Power Switch Replacement: passo 5, immagine 2 di 2
    • Remove the back cover by using the vent hole as a grip.
    • Gently pull out the back cover and let it hang on the side of the speaker that has the knobs and power switch.
    • Unplug the main power lead from the control board; this allows the back to be opened more, allowing easy access to the power switch.
  6. Marshall Kilburn Power Switch Replacement: passo 6, immagine 1 di 3 Marshall Kilburn Power Switch Replacement: passo 6, immagine 2 di 3 Marshall Kilburn Power Switch Replacement: passo 6, immagine 3 di 3
    • Pull the back cover attached to the motherboard to the side as shown in first image.
    • Remove the white insulator from the stereo speaker and place it to the side.
  7. Marshall Kilburn Power Switch Replacement: passo 7, immagine 1 di 2 Marshall Kilburn Power Switch Replacement: passo 7, immagine 2 di 2
    • Place the speaker up right, and unscrew the golden bolt around the power switch with your hands, or a wrench.
    • Gently pull out the power switch as shown in the image.
  8. Marshall Kilburn Power Switch Replacement: passo 8, immagine 1 di 3 Marshall Kilburn Power Switch Replacement: passo 8, immagine 2 di 3 Marshall Kilburn Power Switch Replacement: passo 8, immagine 3 di 3
    • Use a slim spudger to wedge out the four red wires attached to the power switch.
Conclusione
2 Commenti
And where to purchase a new switch???
Anders Skipper - Replica
Does the old switch have any writing on it?
Andrew S -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 63
Tutti i Tempi: 4,827
