Salta al contenuto principale
Marshall Emberton Motherboard Replacement
Cosa ti serve
  1. Marshall Emberton Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • In order to start uncrewing any of the screws off the speaker we have to peel the protective cover off.
  2. Marshall Emberton Motherboard Replacement: passo 2, immagine 1 di 1
    • Pry the front of the speaker off using your nails or a device capable of fitting inside the crevice.
  3. Marshall Emberton Motherboard Replacement: passo 3, immagine 1 di 1
    • Once pried off, we have to remove the eight 1.2 cm screws on the speaker.
    • Use a TR9 screwdriver for the screws.
  4. Marshall Emberton Motherboard Replacement: passo 4, immagine 1 di 1
    • There are six more 1.2cm screws required to remove in order to take out the motherboard.
  5. Marshall Emberton Motherboard Replacement: passo 5, immagine 1 di 2 Marshall Emberton Motherboard Replacement: passo 5, immagine 2 di 2
    • You then need to unplug all three wires connected to the motherboard.
Conclusione
Asia Baldwin
Membro da: 09/26/22
697 Reputazione
5 Guide realizzate
Un commento
How or where can I purchase a new motherboard for my Emberton II? My won’t charge the battery any longer, I’ve since bought another speaker but would like to repair this one if I can get my hands on a new motherboard. Thanks in advance.
jeremy a bolduc - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 78
Tutti i Tempi: 1,024
