Salta al contenuto principale
Marshall Emberton Main Speaker Replacement
Cosa ti serve
  1. Marshall Emberton Main Speaker Replacement, Main Speaker: passo 1, immagine 1 di 1
    • Remove the rubber casing from the speaker by peeling it off using your nails.
  2. Marshall Emberton Main Speaker Replacement: passo 2, immagine 1 di 1
    • Pry the front of the speaker that says "Marshall" in order to get inside the speaker.
  3. Marshall Emberton Main Speaker Replacement: passo 3, immagine 1 di 1
    • Remove the eight 1.2 cm screws using a TR9 screwdriver.
  4. Marshall Emberton Main Speaker Replacement: passo 4, immagine 1 di 1
    • Now pop the speaker out and remove the entire piece.
  5. Marshall Emberton Main Speaker Replacement: passo 5, immagine 1 di 1
    • Now you must disconnect two wire connectors, by firmly tugging on the wires.
    • The new speakers can now be connected and put back together.
Conclusione
Asia Baldwin
Membro da: 09/26/22
697 Reputazione
5 Guide realizzate
Un commento
Hi! Where from can I by the speakers? pls help
Cristian MUNTEANU - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 102
Tutti i Tempi: 2,325
