Salta al contenuto principale
Marshall Emberton Button Replacement
Cosa ti serve
  1. Marshall Emberton Button Replacement, Button: passo 1, immagine 1 di 1
    • Remove the rubber casing from the speaker by peeling it off using your nails.
  2. Marshall Emberton Button Replacement: passo 2, immagine 1 di 1
    • Use a TR9 screwdriver to remove the eight 1 cm screws located on top of the speaker.
  3. Marshall Emberton Button Replacement: passo 3, immagine 1 di 1
    • Once all the screws are off, you must pry the plastic piece off using any tool capable of sliding into the crevice. Then easily pop the piece out.
  4. Marshall Emberton Button Replacement: passo 4, immagine 1 di 1
    • On the back side of the plastic piece, there is a circuit which is shown in the picture. Use a TR9 screwdriver to remove two 1.2 cm screws to detach the circuit from the plastic housing.
  5. Marshall Emberton Button Replacement: passo 5, immagine 1 di 1
    • Once the circuit is removed, you may gently pop the button off and easily replace it with a new one.
Conclusione
Asia Baldwin
Membro da: 09/26/22
736 Reputazione
5 Guide realizzate
3Commenti sulla guida
where can i find a replacement button
MANU 1907 - Replica
The worst instruction I've ever seen in my life. If you do this, you will break your device.
cool eo - Replica
yes, i confirme !!!
Mallet Jp -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 120
Tutti i Tempi: 3,205
