Salta al contenuto principale
Marshall Emberton Battery Replacement
Cosa ti serve
  1. Marshall Emberton Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the rubber casing from the speaker using your nails to peel the cover off.
  2. Marshall Emberton Battery Replacement: passo 2, immagine 1 di 1
    • Pry out both covers that are on the front and backside of the speaker to reveal the screws to get inside the speaker.
  3. Marshall Emberton Battery Replacement: passo 3, immagine 1 di 2 Marshall Emberton Battery Replacement: passo 3, immagine 2 di 2
    • Use a TR9 screwdriver to remove the eight 1.2 cm screws.
    • Use a spudger or opening tool to pry out the speakers.
  4. Marshall Emberton Battery Replacement: passo 4, immagine 1 di 1
    • Use a TR9 screwdriver to remove the six 1 cm screws that secure the motherboard.
  5. Marshall Emberton Battery Replacement: passo 5, immagine 1 di 2 Marshall Emberton Battery Replacement: passo 5, immagine 2 di 2
    • Disconnect the three wire connectors marked, by firmly tugging on the wire.
  6. Marshall Emberton Battery Replacement: passo 6, immagine 1 di 1
    • Use TR9 screwdriver to remove the final two 1.2 cm screws that secure the battery.
Conclusione
Asia Baldwin
Membro da: 09/26/22
697 Reputazione
5 Guide realizzate
2 Commenti
Add any tools at the top you used in this repair guide and also any replacement parts if you can.
Yamilena Hernandez - Replica
How can i buy battery
Rubel hussain - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 109
Ultimi 30 Giorni: 492
Tutti i Tempi: 5,410
