Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Biomed
Attrezzature medicali
Né iFixit né questa guida di riparazione sono approvati dal produttore del dispositivo medicale o affiliati ad esso.
Biomed
Introduzione
If Replace battery is displayed, the battery is unreliable, regardless of the operating time displayed under Batteries. In this situation, replace the battery even when the STATUS window indicates that significant operating time remains. When using an external 12V DC supply, two battery modules must be installed to ensure proper operation. The No battery capacity alarm and high priority technical alarms cannot be silenced.
WARNINGS!
• To guarantee reliable battery backup, two fully charged battery modules must be connected at all times.
• Dispose of batteries according to local regulations and not with ordinary waste.
  1. Find the battery modules on the front of the ventilator.
    • Find the battery modules on the front of the ventilator.
    • To remove a battery module: Pull the lever slightly and press the release button while continuing to pull the lever until the module is released from the ventilator system.
    • Remove the module from the ventilator system.
Conclusione
Cassie Aarrestad
Membro da: 23/01/2020
621 Reputazione
4 Guide realizzate
Cal Poly, Team S7-G2, Paton Spring 2020 Membro di Cal Poly, Team S7-G2, Paton Spring 2020
CPSU-PATON-S20S7G2
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 184
