Salta al contenuto principale
Makita XPH01 LED Light Replacement
Cosa ti serve
  1. Makita XPH01 LED Light Replacement, Battery: passo 1, immagine 1 di 1
    • Hold the drill upright.
    • Place your finger on the white battery-release button.
  2. Makita XPH01 LED Light Replacement: passo 2, immagine 1 di 1
    • Press and hold the white release button located on the front of the battery.
  3. Makita XPH01 LED Light Replacement: passo 3, immagine 1 di 1
    • Slide the battery forward while pressing down on the white battery-release button.
  4. Makita XPH01 LED Light Replacement, Outer Casing: passo 4, immagine 1 di 2 Makita XPH01 LED Light Replacement, Outer Casing: passo 4, immagine 2 di 2
    • Hold the drill upright with the back panel facing you.
    • Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
  5. Makita XPH01 LED Light Replacement: passo 5, immagine 1 di 1
    • Apply slight pressure to the sides of the backplate and pull away from the drill.
  6. Makita XPH01 LED Light Replacement: passo 6, immagine 1 di 2 Makita XPH01 LED Light Replacement: passo 6, immagine 2 di 2
    • Unscrew the nine 18 mm screws from the outer casing using a Phillips PH2 screwdriver.
  7. Makita XPH01 LED Light Replacement: passo 7, immagine 1 di 2 Makita XPH01 LED Light Replacement: passo 7, immagine 2 di 2
    • Apply slight pressure to the sides of the outer casing and pull away from the drill.
  8. Makita XPH01 LED Light Replacement, LED Light: passo 8, immagine 1 di 2 Makita XPH01 LED Light Replacement, LED Light: passo 8, immagine 2 di 2
    • Use the pointed end of a plastic spudger to push the LED out of the drill.
  9. Makita XPH01 LED Light Replacement: passo 9, immagine 1 di 2 Makita XPH01 LED Light Replacement: passo 9, immagine 2 di 2
    • Use the pointed edge of a spudger to pull out the black and white wires located on the left hand side of the drill.
    • Use the pointed edge of a spudger to pull out the plastic connector.
  10. Makita XPH01 LED Light Replacement: passo 10, immagine 1 di 3 Makita XPH01 LED Light Replacement: passo 10, immagine 2 di 3 Makita XPH01 LED Light Replacement: passo 10, immagine 3 di 3
    • Use the flat end of the spudger to push in the clip on the plastic connector.
    • Pull both sides of the plastic connector apart.
  11. Makita XPH01 LED Light Replacement: passo 11, immagine 1 di 3 Makita XPH01 LED Light Replacement: passo 11, immagine 2 di 3 Makita XPH01 LED Light Replacement: passo 11, immagine 3 di 3
    • Pull the silver metal clip on the motor away from the drill.
  12. Makita XPH01 LED Light Replacement: passo 12, immagine 1 di 1
    • Pull the black trigger assembly away from the drill.
  13. Makita XPH01 LED Light Replacement: passo 13, immagine 1 di 2 Makita XPH01 LED Light Replacement: passo 13, immagine 2 di 2
    • Use tweezers to pull out the LED light assembly.
Conclusione
Altre 2 persone hanno completato questa guida.
Eric Herwatt
Membro da: 10/05/16
984 Reputazione
7 Guide realizzate
Cal Poly, Team 15-4, Livingston Fall 2016 Membro di Cal Poly, Team 15-4, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G4
4 Membri
7 Guide realizzate
Un commento
Should I do these steps if my drill is under a warranty?
Richard Williams - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 25
Tutti i Tempi: 2,443
