Introduzione
This guide will show you how to replace the grease in your angle grinder should it become dirty and fail to lubricate the gears.
Cosa ti serve
Check for the provided lock nut wrench. This is used for loosening the piece that keeps the disk and cover attached.
Altre 2 persone hanno completato questa guida.
5 Commenti
Hi, what is the recommended grease?
Hi. You’re great.
Can I use white lithium grease. Thanks my brushes appear to about half an inch long if the grease doesn’t work going to try them????
Angle grinders use a PAO lithium soap grease. Most use Nye Lubricants RheoLube 380, which is hard to source or expensive to buy.
You may substitute with Dupont Molykote G4700 grease. ereplacementParts.com has the Nye grease.
Hi, I’m trying to replace the spindle of my ga4030 with the one from the ga4530, to effectively make it into a 4-1/2” model. Looking at the parts list for both of these grinders, it appears they are identical except for the spindle, disc retaining nuts, and wheel shroud/guard. Do you know if this mod is possible? It looks like I would just need to remove that small bearing that’s pressed on to the top of the spindle.
