Introduzione
These instructions will show you how to replace the rear axle of your Makita DLM431 lawn mower.
Cosa ti serve
Remove lock key and the grass-catching basket.
Put the lawnmower on its head and store it safely.
Loosen the nut of the wheels with a 13mm spanner.
Pull the wheel off the axle
Loosen the nut of the connection between rear axle and axle adjustment with the 13mm nut.
Pull off the axle adjustment linkage.
Remove screws with a Phillips screwdriver.
Push the axle holder backwards through the fairing to expose the axle.
Congrats! Now follow the steps in reverse order to reassemble your unit.
Altre 2 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
carlotremolada ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
