Salta al contenuto principale
Maisto Rock Crawler Remote Circuit Board Replacement
Cosa ti serve
  1. Maisto Rock Crawler Remote Circuit Board Replacement, Remote Circuit Board: passo 1, immagine 1 di 1
    • Remove the batteries before doing anything.
    • Use the driver and bit J1 to remove the five 9.5mm Philips screws holding the remote together.
  2. Maisto Rock Crawler Remote Circuit Board Replacement: passo 2, immagine 1 di 1
    • Take off the half of the remote that had the screw heads facing up.
  3. Maisto Rock Crawler Remote Circuit Board Replacement: passo 3, immagine 1 di 1
    • Slide out the circuit board.
    • Use the soldering iron to desolder the 3 wires.
Conclusione
Altre 5 persone hanno completato questa guida.
kevin
Membro da: 02/10/16
874 Reputazione
6 Guide realizzate
USF Tampa, Team 1-2, Sullivan Spring 2016 Membro di USF Tampa, Team 1-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G2
3 Membri
6 Guide realizzate
5 Commenti
Can you show the wheel controller mechanism. I can see 3 contacts on mine but I think mine is missing something that would bring the contacts together as you turn the wheel to steer left and right. Thanks.
Ferdinand Fong - Replica
the triger is broken to drive the truck
joey heller - Replica
Somebody have the remote control for
Theodore Brock - Replica
I have a 1970 R/T charger RC car, 2.4GHz, I changed it up fully, but the pairing light wont come on. But I can show the lights,the control power is good.what is wrong can anybody help me find the problem and fix it.
Keith Pryor - Replica
How to pair new controller ?
Karel Říha - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 33
Tutti i Tempi: 4,602
