Salta al contenuto principale
Magic Bullet NutriBullet Base Replacement
Cosa ti serve
  1. Magic Bullet NutriBullet Base Replacement, Base: passo 1, immagine 1 di 1
    • Unplug the device from the wall and turn the powerbase upside down.
  2. Magic Bullet NutriBullet Base Replacement: passo 2, immagine 1 di 2 Magic Bullet NutriBullet Base Replacement: passo 2, immagine 2 di 2
    • Unscrew the four 10mm screws located on the bottom of the powerbase using the Phillips Head #2 Screwdriver.
  3. Magic Bullet NutriBullet Base Replacement: passo 3, immagine 1 di 1
    • Once the screws are removed, use slight tension to pull the plastic base up.
    • Make sure the cord does not get caught or frayed by the fan, which is located in the center of the power base.
Conclusione
Altre 3 persone hanno completato questa guida.
Angela Wong
Membro da: 01/22/15
1.156 Reputazione
3 Guide realizzate
Cal Poly, Team 19-8, Maness Winter 2015 Membro di Cal Poly, Team 19-8, Maness Winter 2015
CPSU-MANESS-W15S19G8
4 Membri
13 Guide realizzate
3Commenti sulla guida
So far it was easy! Yeah!
Elaine - Replica
With a lot of force can’t get bottom of even 4 screws removed Bullet don’t work anymore may be a piece of junk now
Tommy Simpson - Replica
Where can you buy the base to replace?
Anne-Christine von Wetter - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 35
Tutti i Tempi: 10,395
