Salta al contenuto principale
Magic Bullet MB1001B Power Cord Replacement
Cosa ti serve
  1. Magic Bullet MB1001B Power Cord Replacement, Power Cord: passo 1, immagine 1 di 1
    • Remove the four rubber pegs from the feet on the base of the Magic Bullet using the spudger.
  2. Magic Bullet MB1001B Power Cord Replacement: passo 2, immagine 1 di 1
    • Remove the four 14.0 mm Phillips head screws in the feet of the base of the Magic Bullet using the Phillips #1 screwdriver.
  3. Magic Bullet MB1001B Power Cord Replacement: passo 3, immagine 1 di 1
    • Remove the black base plate.
  4. Magic Bullet MB1001B Power Cord Replacement: passo 4, immagine 1 di 1
    • Remove the two 13.0 mm Phillips head screws from the white plastic cable guide using a Phillips #1 screwdriver.
  5. Magic Bullet MB1001B Power Cord Replacement: passo 5, immagine 1 di 1
    • Remove the white plastic cable guide.
  6. Magic Bullet MB1001B Power Cord Replacement: passo 6, immagine 1 di 1
    • Remove the two crimp caps from the end of the wires.
    • You will need to purchase new crimp caps and use pliers to crimp the new crimp caps on the connected wires during reassembly.
  7. Magic Bullet MB1001B Power Cord Replacement: passo 7, immagine 1 di 1
    • Separate the black wires of the power cord from the red wires on the Magic Bullet base.
    • Be sure to mark which wires are connected before separating them to ensure that they are properly reconnected during reassembly.
Conclusione
Altre 2 persone hanno completato questa guida.
Bridget Carr
Membro da: 10/06/15
266 Reputazione
1 Guida realizzata
Cal Poly, Team 12-13, Maness Fall 2015 Membro di Cal Poly, Team 12-13, Maness Fall 2015
CPSU-MANESS-F15S12G13
4 Membri
8 Guide realizzate
2Commenti sulla guida
I accidentally burnt through my power cord. What type of power cord do I need to replace it?
virginia.cooke - Replica
Where do we get a new power cord, and if that does not work, what do we do next?
davidcohnkettlebells - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 2,715
