Salta al contenuto principale
Magic Bullet MB1001B Casing Replacement
Cosa ti serve
  1. Magic Bullet MB1001B Casing Replacement, Base Gear: passo 1, immagine 1 di 3 Magic Bullet MB1001B Casing Replacement, Base Gear: passo 1, immagine 2 di 3 Magic Bullet MB1001B Casing Replacement, Base Gear: passo 1, immagine 3 di 3
    • Use pliers to grip the gear inside of the top of the device.
    • You may have to remove a sticker that is covering the slit at the center of the bottom before completing the next step.
    • Insert a flathead screwdriver into the slit at the bottom of the device while still holding the pliers in place gripped on the gear.
    • Lay the device on its side. Holding the screwdriver stationary to hold the bottom side in place, use the pliers to unscrew the gear by turning the pliers CLOCKWISE.
  2. Magic Bullet MB1001B Casing Replacement, Casing: passo 2, immagine 1 di 1
    • Remove the four rubber pegs from the feet on the base of the Magic Bullet using the spudger.
  3. Magic Bullet MB1001B Casing Replacement: passo 3, immagine 1 di 1
    • Remove the four 14.0 mm Phillips head screws in the feet of the base of the Magic Bullet using the Phillips #1 screwdriver.
  4. Magic Bullet MB1001B Casing Replacement: passo 4, immagine 1 di 1
    • Remove the black base plate.
  5. Magic Bullet MB1001B Casing Replacement: passo 5, immagine 1 di 1
    • Remove the two 13.0 mm Phillips head screws from the white plastic cable guide using a Phillips #1 screwdriver.
  6. Magic Bullet MB1001B Casing Replacement: passo 6, immagine 1 di 1
    • Remove the white plastic cable guide.
  7. Magic Bullet MB1001B Casing Replacement: passo 7, immagine 1 di 1
    • Remove the three 11.0 mm Phillips head screws surrounding the white fan blade on the base using the Phillips #1 screwdriver.
  8. Magic Bullet MB1001B Casing Replacement: passo 8, immagine 1 di 1
    • Remove the black base.
  9. Magic Bullet MB1001B Casing Replacement: passo 9, immagine 1 di 1
    • Remove the three white rubber spacers with the spudger.
  10. Magic Bullet MB1001B Casing Replacement: passo 10, immagine 1 di 1
    • Remove the three 11.0 mm Phillips head screws using the Phillips #1 screwdriver.
  11. Magic Bullet MB1001B Casing Replacement: passo 11, immagine 1 di 1
    • Remove the motor.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 12-13, Maness Fall 2015 Membro di Cal Poly, Team 12-13, Maness Fall 2015
CPSU-MANESS-F15S12G13
4 Membri
8 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,897
