Salta al contenuto principale
Magellan Roadmate 9055-LM Touchscreen Replacement
Cosa ti serve
  1. Magellan Roadmate 9055-LM Touchscreen Replacement, Magellan Roadmate 9055-LM Back Panel Disassembly: passo 1, immagine 1 di 1
    • Flip your device with back panel facing up.
  2. Magellan Roadmate 9055-LM Touchscreen Replacement: passo 2, immagine 1 di 3 Magellan Roadmate 9055-LM Touchscreen Replacement: passo 2, immagine 2 di 3 Magellan Roadmate 9055-LM Touchscreen Replacement: passo 2, immagine 3 di 3
    • Unscrew four Phillips #0 screws from the back panel.
  3. Magellan Roadmate 9055-LM Touchscreen Replacement: passo 3, immagine 1 di 2 Magellan Roadmate 9055-LM Touchscreen Replacement: passo 3, immagine 2 di 2
    • Unscrew two Phillips #0 screws from the back panel.
  4. Magellan Roadmate 9055-LM Touchscreen Replacement: passo 4, immagine 1 di 2 Magellan Roadmate 9055-LM Touchscreen Replacement: passo 4, immagine 2 di 2
    • Use a plastic opening tool to pop the right side of the panel.
  5. Magellan Roadmate 9055-LM Touchscreen Replacement: passo 5, immagine 1 di 1
    • Lifting the back panel too quickly or forcefully may damage the speaker cable and battery cable, which are still attached underneath.
    • Gently lift up the back panel.
  6. Magellan Roadmate 9055-LM Touchscreen Replacement: passo 6, immagine 1 di 3 Magellan Roadmate 9055-LM Touchscreen Replacement: passo 6, immagine 2 di 3 Magellan Roadmate 9055-LM Touchscreen Replacement: passo 6, immagine 3 di 3
    • Remove the tape.
    • Unplug the cable for the speaker.
  7. Magellan Roadmate 9055-LM Touchscreen Replacement: passo 7, immagine 1 di 3 Magellan Roadmate 9055-LM Touchscreen Replacement: passo 7, immagine 2 di 3 Magellan Roadmate 9055-LM Touchscreen Replacement: passo 7, immagine 3 di 3
    • Remove the cable of the battery.
    • Tape removal is not necessary.
  8. Magellan Roadmate 9055-LM Touchscreen Replacement: passo 8, immagine 1 di 1
    • Place the back panel gently on the table.
  9. Magellan Roadmate 9055-LM Touchscreen Replacement, Motherboard: passo 9, immagine 1 di 2 Magellan Roadmate 9055-LM Touchscreen Replacement, Motherboard: passo 9, immagine 2 di 2
    • Unscrew four screws in the top left corner by using Phillips #0 size screwdriver.
  10. Magellan Roadmate 9055-LM Touchscreen Replacement: passo 10, immagine 1 di 2 Magellan Roadmate 9055-LM Touchscreen Replacement: passo 10, immagine 2 di 2
    • Remove all the electrical tapes from different places as indicated.
  11. Magellan Roadmate 9055-LM Touchscreen Replacement: passo 11, immagine 1 di 2 Magellan Roadmate 9055-LM Touchscreen Replacement: passo 11, immagine 2 di 2
    • Remove the white clip attached with black and white wires.
    • Carefully remove the clip by pulling it to the opposite side from the clip.
  12. Magellan Roadmate 9055-LM Touchscreen Replacement: passo 12, immagine 1 di 3 Magellan Roadmate 9055-LM Touchscreen Replacement: passo 12, immagine 2 di 3 Magellan Roadmate 9055-LM Touchscreen Replacement: passo 12, immagine 3 di 3
    • Unplug the wires by pushing it down and slowly pulling it towards you.
    • After unplugging the wires, take the motherboard out.
  13. Magellan Roadmate 9055-LM Touchscreen Replacement, Touchscreen: passo 13, immagine 1 di 3 Magellan Roadmate 9055-LM Touchscreen Replacement, Touchscreen: passo 13, immagine 2 di 3 Magellan Roadmate 9055-LM Touchscreen Replacement, Touchscreen: passo 13, immagine 3 di 3
    • Unscrew four Phillips #1 screws.
    • Remove the two metal pieces on two corners.
  14. Magellan Roadmate 9055-LM Touchscreen Replacement: passo 14, immagine 1 di 2 Magellan Roadmate 9055-LM Touchscreen Replacement: passo 14, immagine 2 di 2
    • Lift touchscreen from the right side.
    • Slide the touch screen out from the top left corner.
  15. Magellan Roadmate 9055-LM Touchscreen Replacement: passo 15, immagine 1 di 1
    • Place the touchscreen gently on the table.
Conclusione
YuChe Chang
Membro da: 10/18/16
202 Reputazione
2 Guide realizzate
UMass Dartmouth, Team 1-5, Catania Fall 2016 Membro di UMass Dartmouth, Team 1-5, Catania Fall 2016
UMASSD-CATANIA-F16S1G5
3 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 284
