Salta al contenuto principale
Magellan Roadmate 9055-LM Speaker Replacement
Cosa ti serve
  1. Magellan Roadmate 9055-LM Speaker Replacement, Magellan Roadmate 9055-LM Back Panel Disassembly: passo 1, immagine 1 di 1
    • Flip your device with back panel facing up.
  2. Magellan Roadmate 9055-LM Speaker Replacement: passo 2, immagine 1 di 3 Magellan Roadmate 9055-LM Speaker Replacement: passo 2, immagine 2 di 3 Magellan Roadmate 9055-LM Speaker Replacement: passo 2, immagine 3 di 3
    • Unscrew four Phillips #0 screws from the back panel.
  3. Magellan Roadmate 9055-LM Speaker Replacement: passo 3, immagine 1 di 2 Magellan Roadmate 9055-LM Speaker Replacement: passo 3, immagine 2 di 2
    • Unscrew two Phillips #0 screws from the back panel.
  4. Magellan Roadmate 9055-LM Speaker Replacement: passo 4, immagine 1 di 2 Magellan Roadmate 9055-LM Speaker Replacement: passo 4, immagine 2 di 2
    • Use a plastic opening tool to pop the right side of the panel.
  5. Magellan Roadmate 9055-LM Speaker Replacement: passo 5, immagine 1 di 1
    • Lifting the back panel too quickly or forcefully may damage the speaker cable and battery cable, which are still attached underneath.
    • Gently lift up the back panel.
  6. Magellan Roadmate 9055-LM Speaker Replacement: passo 6, immagine 1 di 3 Magellan Roadmate 9055-LM Speaker Replacement: passo 6, immagine 2 di 3 Magellan Roadmate 9055-LM Speaker Replacement: passo 6, immagine 3 di 3
    • Remove the tape.
    • Unplug the cable for the speaker.
  7. Magellan Roadmate 9055-LM Speaker Replacement: passo 7, immagine 1 di 3 Magellan Roadmate 9055-LM Speaker Replacement: passo 7, immagine 2 di 3 Magellan Roadmate 9055-LM Speaker Replacement: passo 7, immagine 3 di 3
    • Remove the cable of the battery.
    • Tape removal is not necessary.
  8. Magellan Roadmate 9055-LM Speaker Replacement: passo 8, immagine 1 di 1
    • Place the back panel gently on the table.
  9. Magellan Roadmate 9055-LM Speaker Replacement, Speaker: passo 9, immagine 1 di 2 Magellan Roadmate 9055-LM Speaker Replacement, Speaker: passo 9, immagine 2 di 2
    • Unscrew the left and the right screws using the ifixit screwdriver.
  10. Magellan Roadmate 9055-LM Speaker Replacement: passo 10, immagine 1 di 1
    • Now that you removed the screws, you can finally replace the speaker.
Conclusione
Giovanni
Membro da: 10/18/16
313 Reputazione
3 Guide realizzate
UMass Dartmouth, Team 1-5, Catania Fall 2016 Membro di UMass Dartmouth, Team 1-5, Catania Fall 2016
UMASSD-CATANIA-F16S1G5
3 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 142
