Introduzione
Replacing the screen of the Magellan Roadmate 5236T-LM can be helpful for solving problems such as a cracked screen or a screen that isn't sitting properly in the plastic casing. Be sure to use care when disconnecting cables from the motherboard and when applying pressure around the edge of the screen. You don't want to cause any additional damage!
Cosa ti serve
Place the device face down on a flat surface.
Remove the four 5mm screws at each corner using a #000 Phillips head screwdriver.
Place the front panel on a flat surface, screen side down.
Using a plastic opening tool, apply light lifting pressure to each of the 6 casing clips to release the screen from the plastic casing.
Altre 2 persone hanno completato questa guida.
Un commento
This would have been even a GREATER POST if, would have included the part number for the replacement screen,
But,
Just good information as to how to remove the damaged screen.
1975PINTOBOBSTER
