Introduzione
Cracked plastic casing? This guide will help you replace the back cover of the Magellan RoadMate 5236T-LM.
Cosa ti serve
Place the device face down on a flat surface.
Remove the four 5mm screws at each corner using a #000 Phillips head screwdriver.
A ribbon cable attaches the display screen and the motherboard via a ZIF connector. Remove the tape covering where the ZIF connector connects to the mother board.
Use tweezers to disconnect the ZIF connector from the motherboard.
