Salta al contenuto principale
Magellan RoadMate 5120-LMTX Screen Replacement
Cosa ti serve
  1. Magellan RoadMate 5120-LMTX Screen Replacement, Back Cover: passo 1, immagine 1 di 3 Magellan RoadMate 5120-LMTX Screen Replacement, Back Cover: passo 1, immagine 2 di 3 Magellan RoadMate 5120-LMTX Screen Replacement, Back Cover: passo 1, immagine 3 di 3
    • Power off the Magellan RoadMate before beginning.
    • Remove the six 5mm Phillips #00 screws from the back of device.
  2. Magellan RoadMate 5120-LMTX Screen Replacement: passo 2, immagine 1 di 3 Magellan RoadMate 5120-LMTX Screen Replacement: passo 2, immagine 2 di 3 Magellan RoadMate 5120-LMTX Screen Replacement: passo 2, immagine 3 di 3
    • Pry back cover off with a plastic opening tool just enough to see where the speaker is attached to the motherboard.
    • Do not fully open the back cover or you risk damaging the speaker wire.
    • Use a spudger to disconnect the speaker connection from the motherboard.
  3. Magellan RoadMate 5120-LMTX Screen Replacement, Motherboard: passo 3, immagine 1 di 3 Magellan RoadMate 5120-LMTX Screen Replacement, Motherboard: passo 3, immagine 2 di 3 Magellan RoadMate 5120-LMTX Screen Replacement, Motherboard: passo 3, immagine 3 di 3
    • There will be two 5mm Phillips #00 screws that need to be removed from the motherboard.
  4. Magellan RoadMate 5120-LMTX Screen Replacement: passo 4, immagine 1 di 3 Magellan RoadMate 5120-LMTX Screen Replacement: passo 4, immagine 2 di 3 Magellan RoadMate 5120-LMTX Screen Replacement: passo 4, immagine 3 di 3
    • Some devices may have a piece of tape or plastic over the ribbon cable latch. If your device has this, remove it before continuing.
    • Carefully lift the black ribbon cable latch upwards with a spudger or other similar tool.
    • Once the ribbon cable latch is opened, insert the pointed end of the spudger, or other similar tool, underneath the ribbon cable.
    • Slowly pull out the ribbon cable in a straight, flat motion with respect to the latch.
  5. Magellan RoadMate 5120-LMTX Screen Replacement: passo 5, immagine 1 di 2 Magellan RoadMate 5120-LMTX Screen Replacement: passo 5, immagine 2 di 2
    • Be careful not to touch any of the electrical components on the motherboard as damage may ensue.
    • Carefully lift the motherboard out of the plastic housing by the edges while guiding the ribbon cable through the slot.
    • Store the motherboard on a safe non-conductive surface, preferably an anti-static mat.
  6. Magellan RoadMate 5120-LMTX Screen Replacement, Screen: passo 6, immagine 1 di 3 Magellan RoadMate 5120-LMTX Screen Replacement, Screen: passo 6, immagine 2 di 3 Magellan RoadMate 5120-LMTX Screen Replacement, Screen: passo 6, immagine 3 di 3
    • Use a plastic opening tool to release the screen from the tabs.
    • Using too much force can break the tabs.
    • Lift and slide the screen out from the housing.
    • If the screen is cracked, be careful of sharp or loose glass shards.
Conclusione
IUPUI, Team 4-4, Wilson Fall 2016 Membro di IUPUI, Team 4-4, Wilson Fall 2016
IUPUI-WILSON-F16S4G4
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 378
