Salta al contenuto principale
Magellan RoadMate 5120-LMTX Back Cover Replacement
Cosa ti serve
  1. Magellan RoadMate 5120-LMTX Back Cover Replacement, Back Cover: passo 1, immagine 1 di 3 Magellan RoadMate 5120-LMTX Back Cover Replacement, Back Cover: passo 1, immagine 2 di 3 Magellan RoadMate 5120-LMTX Back Cover Replacement, Back Cover: passo 1, immagine 3 di 3
    • Power off the Magellan RoadMate before beginning.
    • Remove the six 5mm Phillips #00 screws from the back of device.
  2. Magellan RoadMate 5120-LMTX Back Cover Replacement: passo 2, immagine 1 di 3 Magellan RoadMate 5120-LMTX Back Cover Replacement: passo 2, immagine 2 di 3 Magellan RoadMate 5120-LMTX Back Cover Replacement: passo 2, immagine 3 di 3
    • Pry back cover off with a plastic opening tool just enough to see where the speaker is attached to the motherboard.
    • Do not fully open the back cover or you risk damaging the speaker wire.
    • Use a spudger to disconnect the speaker connection from the motherboard.
Conclusione
IUPUI, Team 4-4, Wilson Fall 2016 Membro di IUPUI, Team 4-4, Wilson Fall 2016
IUPUI-WILSON-F16S4G4
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 153
