Salta al contenuto principale
Magellan RoadMate 2120T-LM Display Assembly Replacement
Cosa ti serve
  1. Magellan RoadMate 2120T-LM Display Assembly Replacement, Battery: passo 1, immagine 1 di 3 Magellan RoadMate 2120T-LM Display Assembly Replacement, Battery: passo 1, immagine 2 di 3 Magellan RoadMate 2120T-LM Display Assembly Replacement, Battery: passo 1, immagine 3 di 3
    • Turn the GPS over on its backside and remove the six 3 mm Phillips #1 screws.
  2. Magellan RoadMate 2120T-LM Display Assembly Replacement: passo 2, immagine 1 di 2 Magellan RoadMate 2120T-LM Display Assembly Replacement: passo 2, immagine 2 di 2
    • Pry up on back panel with black spudger
  3. Magellan RoadMate 2120T-LM Display Assembly Replacement: passo 3, immagine 1 di 1
    • Disconnect battery and speaker cables from the motherboard at indicated places.
  4. Magellan RoadMate 2120T-LM Display Assembly Replacement: passo 4, immagine 1 di 1
    • Use a spudger to remove the battery from the back panel.
    • If at all possible, please try to use a regular nylon spudger before resorting to a metal spudger. Metal spudgers are much sharper, and have the potential to accidentally pierce the battery.
    • There is a strong adhesive holding the battery to the back panel.
    • This step is not a prerequisite for replacement of other components.
  5. Magellan RoadMate 2120T-LM Display Assembly Replacement, Motherboard: passo 5, immagine 1 di 1
    • Remove the four 3 mm Phillips #1 screws from the motherboard.
    • In the picture three out of four screws have already been removed.
  6. Magellan RoadMate 2120T-LM Display Assembly Replacement: passo 6, immagine 1 di 2 Magellan RoadMate 2120T-LM Display Assembly Replacement: passo 6, immagine 2 di 2
    • Remove black tape covering connection ribbon for touch-screen
  7. Magellan RoadMate 2120T-LM Display Assembly Replacement: passo 7, immagine 1 di 3 Magellan RoadMate 2120T-LM Display Assembly Replacement: passo 7, immagine 2 di 3 Magellan RoadMate 2120T-LM Display Assembly Replacement: passo 7, immagine 3 di 3
    • Pull up on the brown tab holding down the ribbon.
    • In this picture the brown tab has already been lifted.
    • Lift up on the motherboard and remove it from device.
  8. Magellan RoadMate 2120T-LM Display Assembly Replacement, Display Assembly: passo 8, immagine 1 di 2 Magellan RoadMate 2120T-LM Display Assembly Replacement, Display Assembly: passo 8, immagine 2 di 2
    • Pry back on the plastic shell surrounding the touchscreen and remove the screen.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 271
