Salta al contenuto principale
Magellan RoadMate 1440 Power Switch Replacement
Cosa ti serve
  1. Magellan RoadMate 1440 Power Switch Replacement, Magellan RoadMate 1440 Back Cover Disassembly: passo 1, immagine 1 di 1
    • Place the GPS with the screen facing down.
  2. Magellan RoadMate 1440 Power Switch Replacement: passo 2, immagine 1 di 2 Magellan RoadMate 1440 Power Switch Replacement: passo 2, immagine 2 di 2
    • Remove the four 4.2 mm screws on the back cover of the device using a Phillips #0 screwdriver.
  3. Magellan RoadMate 1440 Power Switch Replacement: passo 3, immagine 1 di 2 Magellan RoadMate 1440 Power Switch Replacement: passo 3, immagine 2 di 2
    • Remove the two 4.2mm screws at the bottom of the device using a Phillips #0 screwdriver.
  4. Magellan RoadMate 1440 Power Switch Replacement: passo 4, immagine 1 di 3 Magellan RoadMate 1440 Power Switch Replacement: passo 4, immagine 2 di 3 Magellan RoadMate 1440 Power Switch Replacement: passo 4, immagine 3 di 3
    • Insert the black spudger into the crease in the side of the GPS.
    • Move the end of the spudger down to break the seal between the two plastic shells.
    • Continue doing this along each side of the GPS to ensure a smooth removal.
  5. Magellan RoadMate 1440 Power Switch Replacement: passo 5, immagine 1 di 3 Magellan RoadMate 1440 Power Switch Replacement: passo 5, immagine 2 di 3 Magellan RoadMate 1440 Power Switch Replacement: passo 5, immagine 3 di 3
    • Fully separate the two sides of the case.
    • Remove the tape on the battery wires and the tape on the speaker wires.
  6. Magellan RoadMate 1440 Power Switch Replacement, Power Switch: passo 6, immagine 1 di 1
    • Once the back cover has been removed, lift the power switch from the device.
    • This is only a sliding switch, the button to power the device on is inside the unit
Conclusione
Clemson, Team 7-3, Benson Spring 2016 Membro di Clemson, Team 7-3, Benson Spring 2016
CLEM-BENSON-S16S7G3
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 195
