Introduzione
A guide to accessing the GPS sensor.
Cosa ti serve
Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
Pull the speaker cord, horizontally, by its base, away from the motherboard.
where can we get the speakers from? please
Remove the two screws on that are located on opposite sides of the board.
Lift up the circuit board and disconnect the GPS wire, pulling horizontally from its connector port.
Carefully flip the circuit board out so you can get to the sensor easily.
Remove the tape holding the sensor to the display and take out the sensor.
