Salta al contenuto principale
Magellan RoadMate 1200 Back Cover Replacement
Cosa ti serve
  1. Magellan RoadMate 1200 Back Cover Replacement, Back Cover: passo 1, immagine 1 di 2 Magellan RoadMate 1200 Back Cover Replacement, Back Cover: passo 1, immagine 2 di 2
    • Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
  2. Magellan RoadMate 1200 Back Cover Replacement: passo 2, immagine 1 di 1
    • Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
  3. Magellan RoadMate 1200 Back Cover Replacement: passo 3, immagine 1 di 2 Magellan RoadMate 1200 Back Cover Replacement: passo 3, immagine 2 di 2
    • Remove the back cover from the device by separating the back cover along its seam.
    • Slowly lift the cover—the speaker is screwed onto the back cover and is connected to the circuit board.
  4. Magellan RoadMate 1200 Back Cover Replacement: passo 4, immagine 1 di 2 Magellan RoadMate 1200 Back Cover Replacement: passo 4, immagine 2 di 2
    • Pull the speaker cord, horizontally, by its base, away from the motherboard.
    • When reassembling, make sure that you plug the terminal in the same way. The black wire should be on the side farthest from the battery.
Conclusione
Altre 2 persone hanno completato questa guida.
Ross Light
Membro da: 04/12/10
217 Reputazione
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 3,467
