Introduzione
Use this as a guide to repair the USB cable when its internal connection to the controller is damaged.
Cosa ti serve
Locate the four 8.3 mm Phillips screws on the circuit board and remove them.
Orient the motherboard so that the side with the rubber buttons is facing up.
Remove the rubber buttons by pulling up on the on the rubber pad on the points where the rubber cylinders that poke through the motherboard are so that each cylinder slides out nicely.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Push or pull the broken or disconnected wire through its respective hole on the front side of the motherboard so that the metal part of the wire is sticking out the back side of the motherboard.
Use the soldering kit to solder the wire onto the back side of the motherboard.
To reassemble your device, follow the instructions starting from step eight in reverse order.
For specific instructions on soldering, check out the iFixit soldering guide.
