Salta al contenuto principale
Mad Catz Rock Band 4 Wireless Fender Strum Bar Replacement
Cosa ti serve
  1. Mad Catz Rock Band 4 Wireless Fender Strum Bar Replacement, Outer Casing: passo 1, immagine 1 di 1
    • Flip the guitar over so it is back side up. The battery compartment should be facing up.
    • Use a size J1 head screwdriver to remove the ten 5 mm short screws.
    • Use a J1 screwdriver to remove the four 5 mm long screws on the back of the device.
  2. Mad Catz Rock Band 4 Wireless Fender Strum Bar Replacement: passo 2, immagine 1 di 1
    • Turn the device over so the front of the guitar is facing you.
    • Using a size J1 philips head screwdriver, remove the eleven 5 mm silver screws (circled in red) around the white panel.
  3. Mad Catz Rock Band 4 Wireless Fender Strum Bar Replacement: passo 3, immagine 1 di 1
    • Gently lift the white panel and twist 90 degrees clockwise.
    • Using a size J1 head screwdriver, remove the two 5 mm black screws from underneath the white panel. You should now be able to pull the guitar apart.
  4. Mad Catz Rock Band 4 Wireless Fender Strum Bar Replacement, Strum Bar: passo 4, immagine 1 di 1
    • Using a size J1 head screwdriver, remove the six black 5 mm screws (circled in red) from the back of the strum button component.
  5. Mad Catz Rock Band 4 Wireless Fender Strum Bar Replacement: passo 5, immagine 1 di 1
    • Lift out the circuit boards from above and below the strum component.
    • Unplug the circuit boards connected to the strum component from the main circuit board.
    • You should now be able to pull out the strum bar.
Conclusione
USF Tampa, Team 1-1, Cagle Fall 2016 Membro di USF Tampa, Team 1-1, Cagle Fall 2016
USFT-CAGLE-F16S1G1
4 Membri
6 Guide realizzate
2 Commenti
Where can I fand a replacement part?
Logan Sturdivant - Replica
The Strumfix Plus 4 from ByteArts is what I used for mine.
Ted Lawson -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 21
Tutti i Tempi: 4,399
