Salta al contenuto principale
Mad Catz Rock Band 4 Wireless Fender Power Button Replacement
Cosa ti serve
  1. Mad Catz Rock Band 4 Wireless Fender Power Button Replacement, Outer Casing: passo 1, immagine 1 di 1
    • Flip the guitar over so it is back side up. The battery compartment should be facing up.
    • Use a size J1 head screwdriver to remove the ten 5 mm short screws.
    • Use a J1 screwdriver to remove the four 5 mm long screws on the back of the device.
  2. Mad Catz Rock Band 4 Wireless Fender Power Button Replacement: passo 2, immagine 1 di 1
    • Turn the device over so the front of the guitar is facing you.
    • Using a size J1 philips head screwdriver, remove the eleven 5 mm silver screws (circled in red) around the white panel.
  3. Mad Catz Rock Band 4 Wireless Fender Power Button Replacement: passo 3, immagine 1 di 1
    • Gently lift the white panel and twist 90 degrees clockwise.
    • Using a size J1 head screwdriver, remove the two 5 mm black screws from underneath the white panel. You should now be able to pull the guitar apart.
  4. Mad Catz Rock Band 4 Wireless Fender Power Button Replacement, Power Button: passo 4, immagine 1 di 1
    • Using a size J1 philips head screwdriver, remove the two black 5 mm screws (circled in red) from the back of the power button component. You can identify this by the code J5-B on the component.
  5. Mad Catz Rock Band 4 Wireless Fender Power Button Replacement: passo 5, immagine 1 di 1
    • Using your hands, lift the small, rectangular circuit board off and follow the connecting cords to the main circuit board.
    • Unplug the cord connected to the battery component from the main circuit board.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team 1-1, Cagle Fall 2016 Membro di USF Tampa, Team 1-1, Cagle Fall 2016
USFT-CAGLE-F16S1G1
4 Membri
6 Guide realizzate
Un commento
I need two Rock Band 4 Home Button/Bluetooth Replacement Parts, where to locate??
My name is Robert.
Thank you in regards to whom can assist
Robert Houser Jr - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 24
Tutti i Tempi: 3,233
