Salta al contenuto principale
Mad Catz Dual Force 2 Pro Rear Cover Replacement
Cosa ti serve
  1. Mad Catz Dual Force 2 Pro Rear Cover Replacement, Remove the Screws: passo 1, immagine 1 di 1
    • Using the Phillips #1 screwdriver, remove the six 7 mm screws from the rear cover.
  2. Mad Catz Dual Force 2 Pro Rear Cover Replacement: passo 2, immagine 1 di 2 Mad Catz Dual Force 2 Pro Rear Cover Replacement: passo 2, immagine 2 di 2
    • After removing the screws, you will be able to lift the rear cover of the controller.
    • There are no loose items in the controller that can fall out, so you can open it without extreme caution.
Conclusione
USF Tampa, Team 7-2, Remmell Winter 2015 Membro di USF Tampa, Team 7-2, Remmell Winter 2015
USFT-REMMELL-W15S7G2
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 8
Tutti i Tempi: 282
