Salta al contenuto principale
Mad Catz Dual Force 2 Pro Motherboard Replacement
Cosa ti serve
  1. Mad Catz Dual Force 2 Pro Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Remove the six 7 mm Phillips screws from the rear cover.
  2. Mad Catz Dual Force 2 Pro Motherboard Replacement: passo 2, immagine 1 di 1
    • Remove the back of the controller.
    • There are no loose items in the controller that can fall out, so you can open it, generally, however you want.
  3. Mad Catz Dual Force 2 Pro Motherboard Replacement: passo 3, immagine 1 di 1
    • Remove the two 7 mm screws on the closest circuit board.
  4. Mad Catz Dual Force 2 Pro Motherboard Replacement: passo 4, immagine 1 di 2 Mad Catz Dual Force 2 Pro Motherboard Replacement: passo 4, immagine 2 di 2
    • Lift the closest circuit board away from the motherboard.
    • Be sure you do not tear the ribbon connecting the smaller circuit board to the motherboard.
  5. Mad Catz Dual Force 2 Pro Motherboard Replacement: passo 5, immagine 1 di 1
    • Remove the two 7 mm Philip screws on the motherboard.
  6. Mad Catz Dual Force 2 Pro Motherboard Replacement: passo 6, immagine 1 di 1
    • Remove the motherboard assembly from the cover.
Conclusione
USF Tampa, Team 7-2, Remmell Winter 2015 Membro di USF Tampa, Team 7-2, Remmell Winter 2015
USFT-REMMELL-W15S7G2
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 586
